Author Topic: Cycling Records  (Read 1914 times)
Atalm93
  • Team: Flyvende_hjul CFF2team: Averatalm
Cycling Records
« on: November 01, 2018, 10:36:42 PM »
I have noticed that a Cyclist get a top10 result from GC in a tour on his record page, but when it comes to one-day races, they do not show.
Re: Cycling Records
« Reply #1 on: November 01, 2018, 10:42:58 PM »
You must put here the link to check it, but in Tour Down Under I saw some cyclists and works fine.
« Last Edit: November 01, 2018, 10:45:06 PM by oscacom »
Atalm93
Re: Cycling Records
« Reply #2 on: November 02, 2018, 05:02:57 PM »
http://www.managercycling.com/cff/histori.php?ciclistaid=908
This rider won Strade Bianche, but on his result page, it does not stand nr1 behind the race.
However, his 4th place from TDU you can see.
Re: Cycling Records
« Reply #3 on: November 02, 2018, 05:43:57 PM »
Not a bug, in races results are stored in divisions, I only put in this table 1a results .
In can show actual division and when you are in 1st division you can see other seasons, but at moment you are in 2nd you cannot see old 1st division results.
In tours there is an special table that save top10 after the season, but during season you can see actual results.
At the end of the season all not 1a results are deleted.
Not easy explain it in english for me but due technical reasons it can't be changed, in normal Cff works as here.
