Author Topic: race Stars  (Read 3624 times)
Frier_Accounting
race Stars
« on: November 26, 2018, 04:05:58 PM »
You show the Stars (Climbing, Flat, etc.) for each race.  You stated that these are used to assist in calculating each race's GV.  Unfortunately, once the race is complete, you can not go back and view the suggested stars.  You can also not go ahead to next season or even past a certain race for this current season.  If it remains this way then the Stars are of no use in planning for the next season of races as they can not be viewed.  In reality, what use are the stars then?  Are they really only there for new players?
Re: race Stars
« Reply #1 on: November 26, 2018, 05:10:53 PM »
Make an archive of stars in races! Should not be that difficult for an accountant...
Re: race Stars
« Reply #2 on: November 26, 2018, 06:59:21 PM »
Stars are a little help before sign up for races.
Not a big problem take note, and when you have experience you don't need my stars because one star can be 5% or 14% a big difference or same 3 stars 26% or 50%.
But new players can know what is important in race engine.
bemiluba
Re: race Stars
« Reply #3 on: November 27, 2018, 03:10:19 PM »
Facilitar con estrellas a los principiantes está bien  ;).
Aún así pienso que deberíamos empezar a cuidar el aspecto del juego. Es como todo en la vida, si queremos atraer nuevos jugadores, lamentablemente, lo primero que van a ver es el aspecto del juego. Si les llama la atención primero, luego se meterán en detalles.  Lo digo porque las estrellas aparecen bastante desalineadas, lo que hace que a veces no se entiendan bien. No se si, reduciendo el tamaño de las mismas se arreglaría el problema. Lo comento por si se pudiera hacer algo.
Un saludo.
Frier_Accounting
Re: race Stars
« Reply #4 on: November 27, 2018, 07:53:13 PM »
Very true Oska.  I've been checking the current season and in the Beta with your stars for CFF3.  I'm off on some percentages (going up or down a star), but I'm usually in that range.
Would love to be able to see the Stars for past races or even for the upcoming season.  Would definitely help with setting the next season's race roster.
Frier_Accounting
Re: race Stars
« Reply #5 on: November 30, 2018, 12:55:25 PM »
Certainly not, but I was a little busy at the beginning and just started updating my spreadsheets.  Would be nice to go back and see what they were, to know how close my GVs are.
Anything else to add???
