Author Topic: Skills stars for Ruta por avila (La Vuelta stage 2)  (Read 6055 times)
« on: February 25, 2022, 09:22:42 AM »
If you take the minimum % of each skills, it adds 105%.
Climbing 25%
Cobblestone 25%
Downhill 15%
Hills 15%
Stamina 15%
Aggressiveness 5%
Technique 5%
Not that it affects anything in the game, but just to mention it.
Re: Skills stars for Ruta por avila (La Vuelta stage 2)
« Reply #1 on: February 25, 2022, 10:12:30 AM »
Oska has indicated in the past that the total value of the combined skills can be under or above 100%. That indeed is a contradiction ("I see you are working 60% on this project, what are you doing in the remaining 140%?...  :) ). So rather than percentages you should see them as points which can remain under 100 or exceed 100. I personally think that the percentages in the explanation below the stars should be removed. But I am a mathematician, there might be other opinions about this.
« Reply #2 on: February 25, 2022, 11:20:30 AM »
I guess that's why it's 280kms.
« Reply #3 on: February 25, 2022, 02:07:50 PM »
Good to know. Although as Combuijs says it makes no sense. If you don't know the total sum then the number that the stars indicate is completely useless. I guess that if the sum is always close to 100, you can rely on the numbers with some small error. But not being completely sure of that, I'd rather have a list of all skills that count ordered by importance than the stars.
